Old 03-12-2017, 02:57 PM
camdigger's Avatar
Roving Reporter
Default Preferred method to join cast iron to mild steel?
I have a cast iron part that is broken and the matching piece is long gone. The original material is a cast iron. One potential repair is to make up a repair part out of mild steel of approximately the same 1/4" thickness and join the two pieces to do the repair.
There is restricted clearance on the back of the repair, so mechanical fasteners are not feasible, IMHO.
What process would be best to do this?
An alternate method might be to make up a dummy repair, mate to the broken part, and use that as a pattern to sand cast an Aluminum replacement part. That would mean setting up my backyard foundry again and playing with it till I got a successful replacement made.
Yet another alternative might be to fabricate the complete part out of mild steel.
Old 03-12-2017, 03:29 PM
I have done what they call buttering the cast with machinable nickel rod and finish with 7018
Old 03-12-2017, 05:46 PM
I usually use nickle rod for joining steel to cast, providing it is not been overheated and not weldable.
Old 03-12-2017, 06:29 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Me personally if it was a low stress application I would just braze it. I have a rod called cronatig211 that seems to work pretty well but its not cheap but have used stainless rod in a pinch with good enough results.
Here are a few cast repairs I have done, but none were specifically iron to steel
http://shopfloortalk.com/forums/show...highlight=cast
Old 03-12-2017, 08:42 PM
Make your missing piece out of steel and weld it with Ni-Rod. Either cold stitch and peen, or preheat and go at it. A while back I did a tractor transmission and posted here, and I put in a piece of steel to fill in the missing part. It's still going along.
Old 03-12-2017, 11:45 PM
That is how I do it, butter with 99% nickel rod then weld your steel to the nickel with 7018.
Old 03-13-2017, 02:49 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
What is the difference between brazing and nickel rods?
Boise Paint Contractor
Facebook
How fortunate we are!
Old 03-13-2017, 04:19 PM
How brazing works
