Old 03-14-2017, 06:50 PM
Default Mag Drill Base
Got a start on the mag drill base today. Made from 6"x1/4" flat bar. Need the extra height so I can use the chuck adapter I made for standard drills. Broke down and bought new steel for this project. Got 5 sides cut fit up and welded today. Not a big fan of 6013, but need to use up a 50 lb. can somehow. Satisfied with the welds from an old blind guy.
Leaving the last end piece until I decide the design for small parts that are too small for the mag drill, like something less than 12" long. Still not sure how I am going to clamp them to the end of the base. I left the end open so I have access to the inside for welding if necessary.
The base is 6"x6"x10" welded with 6013 at 110 amps. I am also adding tabs on the outside at each corner so I can bolt it to the welding table.
More later when I figure out the clamping design.
ID:	138332   Click image for larger version
ID:	138333   Click image for larger version
ID:	138334   Click image for larger version
ID:	138335   Click image for larger version
Old 03-14-2017, 10:00 PM
How about something like this leaving the front open?
ID:	138339   Click image for larger version
Old 03-14-2017, 10:09 PM
I did think about that but wondered how I would hold the piece while drilling???
Old 03-14-2017, 10:36 PM
The stand offs would allow for clamping
Old 03-14-2017, 11:10 PM
The gray part is the box I already built?
Old 03-15-2017, 03:59 AM
clive's Avatar
clive clive is offline
Are you going to use the magnet to hold it in place? I have known them to let go on 1/4 plate, might pay to put another bit inside to make it up to 1/2" and plug weld it in. Embarrasing when they let go ( how do I know that?)
It's So Easy
Old 03-15-2017, 06:41 AM
Vernon's Avatar
Vernon Vernon is offline
Default Turned a Magnetic Drill into a drill Press
I like my design maybe this can help you Milomilo. http://www.shopfloortalk.com/forums/...ad.php?t=25790
Due to the lack of effort today Tomorrow has been canceled...................
Old 03-15-2017, 12:29 PM
Side view with a cut out to allow for wider stock and with three stand offs to allow for clamping a stability
Old 03-15-2017, 12:36 PM
I like the standoff idea digr. Looked through the resource pile and fond a piece of 12" wide by 1 1/2" leg channel. The 1 1/2" leg lets me get a 3" C clamp in to hold the small parts. I like the thought of making it portable and still allow it to be bolted to the weld table too. I will weld some angle iron clips to the base and use 3/8" bolts to attach to the channel or to the weld table. Let me know what you think of the layout on the pics.
ID:	138353   Click image for larger version
Old 03-15-2017, 12:52 PM
I am adding a 12" plate inside the base so I will have much better mag attraction. Thanks for reminding me. I have to look for a scrap piece today.
