Old 03-15-2017, 12:54 PM
Side view with a cut out to allow for wider stock and with three stand offs to allow for clamping a stability
Another good idea!! Thanks.
Old 03-15-2017, 01:08 PM
I am kind of lost here, don't you have to raise your mag drill up six inches?
Are you going to notch your box to allow for wider stock?
I don't understand the vee shape you have laid out.
The channel should work fine.
Old 03-15-2017, 01:19 PM
In the pic the dotted lines are the drill The 6" box sits under the drill. I just did not add that to the layout. Now you got me thinking to cut in a notch for wider stock.
Old 03-15-2017, 01:20 PM
The V shape is cut out so I can slide in clamps to what ever the width of the material is.
Glad you're gonna thicken up the "grab" surface, I added 1/2" to the 3/8" web thickness of the 10" channel mine's made of - haven't had a "oopsie" caused by magnet pull-off yet, biggest I've done so far is 1-1/2" hole thru 3/4 plate -
If you figure out how to make the short stroke of a mag drill work with twist drills that vary in length by about 3", I'd love to see it - been mulling that one around off and on for a couple months now. Got a couple ideas, but keep finding reasons I DON'T like 'em ...Steve
Old 03-15-2017, 01:25 PM
I expect I will just not be able to use large size new drills, only older worn down drills.
Old 03-15-2017, 01:33 PM
Like this maybe but with a 1/2" plate on top of the box
Old 03-15-2017, 01:37 PM
Yup. Just like that, except with the channel on the bottom.
Old 03-15-2017, 01:38 PM
How much notch you think?
Old 03-15-2017, 01:48 PM
I would go as much as you can, maybe about half the length of the mag, the more you notch the wider the stock you can drill.
