JR Welding Tools
  #41
Old 09-13-2016, 09:11 PM
duckman903 duckman903 is offline
Jen I assume you have an arc welder you just have to run 3 or 4 3/8" long beads in in the race and it will fall, take a small rod (3/32" or 1/8") bend the end so you can weld a bead on the ID of the bearing, I've litterly taken dozens of Timken outer races out of gear boxes and the welding never failed me.
  #42
Old 09-14-2016, 07:39 PM
I'll more than likely try the tig torch as I have long cups and I should be able to get down in there..
The blower with the work I have done sounds pretty decent.. Once the bearing is in it will make a much better ideal..
_________________
Jennifer
My google+ page
DoALL 36"
  #43
Old 07-03-2017, 04:32 PM
ozhunter ozhunter is offline
Hi, did you come up with a solution to get the race out and replace the bearing? I have the same problem with my 14"
Regards
Adam
  #44
Old 07-03-2017, 04:41 PM
Regards
Adam
HI Adam. Not that I don't doubt you but the 14" up till the sheet metal ones have a full sized bearing I believe it has 2 magneto bearings.. I'll look again later but I remember being able to knock it out from the other side once the plate which is threaded in is removed...
If you post a picture of the blower it would help me out a lot.
Sent from my SM-N910C using ShopFloorTalk mobile app
_________________
Jennifer
My google+ page
DoALL 36"
  #45
Old 07-03-2017, 05:12 PM
Thanks for replying.
It is a 14" all cast with all original parts, including grease and busted ball cage.
I should start my own thread so I don't hijack yours.
Regards
Adam
ID:	139955   Click image for larger version
