  #51
Old 01-27-2017, 01:58 AM
Silverback's Avatar
Silverback Silverback is offline
I know exactly what the stock one looks like (see the attached), I have a part number and like I mentioned already, Kellogg and the distributor that they put me in touch with couldn't locate one.
I don't know how heavy the thing is but it is smaller in diameter then the pulley I have (which I'm sure is lighter but the larger diameter might make up for it). Honestly, if I had the stock pulley I'd either need a much larger or a lower rpm motor to turn it.
Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
BFH
  #52
Old 01-27-2017, 08:36 AM
alchemist's Avatar
I would just try it. If it doesn't work it would be fairly easy to attach a flywheel to the pulley.
