Old 10-08-2016, 10:12 AM
KevinF KevinF is offline
Originally Posted by Cavalry View Post
I'm curious why you cut the joists at an angle. It looks pretty neat, but doesn't it reduce the load capacity of the cantilever?
The taper is purely aesthetic. The last 24 inches taper to a 2x6. The cantilever doesn't bear much for load other than itself, eventually a railing, and the live load. The stairs are hung from a double joist and the first one is not tapered.
Poor lad needs to get a real camera
Bah! The fisheye effect is so hip though!
Old 12-12-2016, 03:22 PM
Got all the OSB sheeting up. Looking at best options for PVC or puck board type sheeting in the bathroom so nothing is sheeted in there. For the meantime at least the vapor barrier is up in the bathroom. Had a brisk cold snap move in last week. Got the LED recessed lighting in upstairs.
Nothing else to report. Spent a lot of time travelling for work. Hunted a little in November. Helped neighbour make an awful mess in my shop. He brought Case mix mill over to work on. Half full. Of course it was torn apart on the hoist and we found out that it in fact would need to be emptied out, contrary to his initial theory. Very dusty.
Old 12-12-2016, 10:02 PM
rustythe4x4's Avatar
Looking good Kev.
My expansion is on hold. Springtime it is.
Living the country life
Mathew 10:36
-Ironman quoting the Bible
Old 12-12-2016, 10:05 PM
That sure is a crooked room.
I want to go home!
Old 12-12-2016, 10:14 PM
Thats looking great! What are the plans for the loft?
Old 12-14-2016, 01:07 PM
Some shelving around part of the outside. Rail and bar stools on the side above the fridge. Couch and 454 coffee table. Maybe a wood stove. Probably a desk of some sort. There is a lot of square footage up there that I don' think I have allocated.
Old 12-14-2016, 01:48 PM
Originally Posted by KevinF View Post
There is a lot of square footage up there that I don't think I have allocated.
That won't take long to resolve!!!!
Old 12-14-2016, 04:35 PM
kbs2244 kbs2244 is offline
If you hurry and paint it all white before you so anymore it will make the curve less noticeable.
Old 12-14-2016, 10:39 PM
Planning to blast some paint in there asap.
Currently working 2 provinces west, in the north.
I also finished screwing all the sheets so they don't droop like pictured.
I ran 2 extra 220 drops into the area under the mezz. That will be where the metal working stuff hangs out. It will be nice to have it out of the way in the shop area. Also will be nice to have the open bay full length, no bench there. Wish previous owner had done a better job with vapor barrier. Lazy azz Actually wish he had done a better job with a lot of things. oh well.
Old 01-07-2017, 11:56 AM
Needs another coat on the mezz floor/stairs. Ended up just rolling everything because my paint sprayer friend was busy while I was home. He did hook me up with really good price on the primer and paint. About 8 gallons primer and 5 paint laid so far.
Looked at a price for 4x8 sheets of palight board for the walls but $140 per sheet is a little much. Seems there isn't any PVC / plastic veneer/board that is really affordable. If I do half the bathroom I would need 7 or 8 sheets. Maybe just drywall it and use good hard glossy paint to seal it up.
First pic is primer, then the rest paint. Sure did make it look big. For the floor I just tinted the flat white with some latex enamel I had sitting around so it ended up kind of battleship green.. I will get another coat on of something maybe a greenish grey tint.
ID:	137372   Click image for larger version
ID:	137373   Click image for larger version
ID:	137374   Click image for larger version
ID:	137375   Click image for larger version
