JR Welding Tools
Old 03-03-2017, 11:58 AM
JWBIRONWORKS's Avatar
JWBIRONWORKS JWBIRONWORKS is offline
As pictured they run $400 dollars. Pick up in suburban Jessup Indiana or an IBA meeting if Im headed that way.
Trying to make a living with fire,anvil and a hammer
http://www.jbartistblacksmith.com
Old 03-03-2017, 01:34 PM
https://www.abana.org/ronreil/burner.gif
Old 03-03-2017, 01:35 PM
http://www.hybridburners.com/index.html
Old 03-18-2017, 02:36 PM
alchemist's Avatar
Is coal readily available or does it just depend on where you live? I would like to make a coal forge but I don't know where to get coal. If I can't find any I will copy your design if it's ok.
Old 03-18-2017, 02:43 PM
I drive 2 hours one way to get my coal. It's not really my design. Build away.
Old 04-01-2017, 08:41 PM
seagiant's Avatar
seagiant seagiant is offline
Hi,
I've built a few, but prefer a gas/air mix! (air is free!)
You do have to have power in the shop for the air which some people dont!
I also take Satinite and cover the KWool!
If I am forge welding I make a pan for the bottom to protect the flux from "melting" the K Wool!
There is a LOT of info on these and I would urge anyone new to Blacksmithing to join their local ABANA Chapter for their State, and go to a few meetings!!!
Old 04-21-2017, 12:33 PM
camdigger's Avatar
camdigger camdigger is online now
Roving Reporter
Nice forge.
I have seen a gas fired forge that was built using a rigid board type insulation (Vermiculite board?). The forge was built as a rectangle out of 10 gage sheet stock and lined with the rigid board, but with a castable refractory floor. The builder told me he preferred the rigid board because he could work it with a woodworking saw and it was a bit more durable than the ceramic wool.
Now to find the rigid insulation.....
