Old 07-05-2017, 06:54 PM
Firefighter615 Firefighter615 is offline
Default NEW Eastwood TIG200 AC/DC Welder
I just pulled the trigger on my first NEW welder, it is an Eastwood TIG200 AC/DC Welder.
Eastwood TIG 200 Welder...industrial TIG features at a DIY price!
Now with Stick Welding Feature!
Stick welds in AC and DC Positive/Negative
Operates on either 110vAC, 15-amp circuit or 220vAC, 30-amp circuit
1/4"-thick welding capacity on 220VAC
High-frequency start for precise arc control
Square-wave inverter for accurate aluminum welding
"WP-17"-type torch accepts common cups and collets, up to 1/8" electrodes
TIG Welding AC Duty Cycle (%): 120VAC 60% at 145 amps, 220VAC 60% at 190 amps)
The specially engineered 200-amp Eastwood TIG Welder offers affordable, professional-quality TIG welding on aluminum, stainless or steel (sheet, tube or bar stock), and precise welding of thinner-gauge materials up to 1/4" thick.
Old 07-05-2017, 07:47 PM
Give it a good work while it is in Warranty
especially the High frequency, being high voltage likely the weakest thing.
Hope it has IGBT transistors, likely new welders do.
Old 07-05-2017, 07:58 PM
You should be a salesman.
Old 07-05-2017, 08:03 PM
I think he is
Old 07-05-2017, 08:16 PM
Nope not a salesman just copied the specs from the web site. I am just very happy to get a new machine.
Old 07-05-2017, 08:44 PM
Kenny Tarmac strikes again.
Note: all spammers use this same line "I'm just a happy customer".
Old 07-05-2017, 09:18 PM
Slow down you All.
he registered Sep/2013.
Old 07-05-2017, 10:00 PM
Slow down you All.
Wow! Took him 4 years to make his first post!
Old 07-05-2017, 10:34 PM
Gadgeteer's Avatar
Took him 4 years to learn how to weld by reading about all the fun we have, here.
Old 07-05-2017, 11:55 PM
Don't listen to those grumpy bastards--I don't think they've had their meds today...
Anyhow, Fire615, welcome aboard. Which model did you get? The $699 special isn't a bad deal at all! Feel free to ask any welding questions you may have and we will expect a full report with some weld pics once you get it up and running...
