Old 09-03-2017, 03:49 PM
jamesemery728 jamesemery728 is offline
Default Mystery Tool
Anyone know what this tool is supposed to be used for? It looks like it forces a wedge against something to separate it.
Sent from my GT-N5110 using Tapatalk
Last edited by cutter; 09-03-2017 at 05:03 PM. Reason: remove embedded image, upload as attachment
Old 09-03-2017, 05:56 PM
Maybe to separate front end parts like tie-rods and ball joints.
Old 09-04-2017, 02:20 AM
Looks like something Kent Moore would make for working on large engines or suspension parts for large trucks.
Old 09-04-2017, 09:19 AM
Thanks for all the suggestions guys. The slot in this tool is less than 7/16" wide and the total tool length is only about 4" so it's rather lightweight. Probably too light for car or large truck applications. Definitely made for separating something, I just dont know what.
Old 09-04-2017, 09:59 AM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
It could be used as a really, really, really slow cherry pit remover. ...but then again, maybe not.
Old 09-04-2017, 10:06 AM
Front sight pusher... well except for the wedgy part.
Old 09-04-2017, 10:16 AM
Grizz Grizz is offline
I may be designed to raise a normally locked adjuster into adjusting position, Some heavy truck air brake slack adjusters needed a lock pin to be raised to let you back them of, although I think this tool is too large for that, the tool that I made for that application is a ramp ground on the jaws of a 3/8 open end wrench, but the concept is similar
Old 09-04-2017, 09:40 PM
5500bill 5500bill is offline
The tool is used to separate the shift linkage from the plastic grommet on Ford transmissions and transfer cases. I used it when I was working in a Ford dealership. Two well placed pry bars work better than that tool
Old 09-04-2017, 11:01 PM
I knew someone here would know. You guys rarely fail.
Thanks, bill.
I want to go home!
Old 09-08-2017, 06:22 PM
Thank you Bill I knew someone would know what it was for.
