Old 07-04-2016, 06:11 PM
Default Rong Fu Mill/Drill head lift guide
This is food for thought for tackit in the midst of his travails with his mill/drill.
Some of you may remember I built a motorized head lift for Mildred a couple or three years ago. I was hoping that it might at least minimize the rotational drift from registration experienced with round column mills.
It did not.
I have posted a You Tube video which demonstrates that she still shifted both to the right and to the left a 1/2 an inch or so under travel.
The indicator in this video is not touch the test bar; it is only a pointer to show how much drift there is.
So I worked for about a year, off & on, to build a guide bar to at least minimize this rather glaring deficiency so that poor old Mildred could feel prouder of her performance. This was inspired by the one Mark Ball posted a couple of pictures of 2 or 3 years ago.
I did not post this build project because of the tedium involved, the false starts & do over's and the general frustration all that entailed, scattered over most of 2014.
But I do have another You Tube video showing the result. It limits her error to plus or minus .005" and she usually settles down to about zero when the motor switches off.
Not perfect but honestly, for the kind of work I get around to doing it is generally good enough & certainly a lot better than trying to use that damned crank, which now resides in a drawer.
Head lift guide video # eleventyfortyone or something.
In this case the indicator is in contact with that old WWII boring bar from my grandfather's tool chest.
I want to go home!
Old 07-04-2016, 07:53 PM
clive's Avatar
clive clive is offline
Cutter, I have a mill/drill ( but with a tilting head) and the round column is a pain, I tried to find the alterations you did to steady it but couldn't. Do you have a link to that?
Clive
It's So Easy
Old 07-05-2016, 08:33 AM
Director: Fish Seduction
That's pretty darn good, and better than most will ever get out of their machines. Great job!
www.nfpd.us
Old 07-05-2016, 09:03 AM
tackit's Avatar
tackit tackit is offline
That's really great work cutter, I'm impressed.
Old 07-05-2016, 12:23 PM
Clive
I did not post a thread about it, Clive. I took hundreds of pictures along the way, most of which are details but they are disorganized and probably not very helpful unless I put a lot of time into trying to recover my memory of "what was that all about?" It really was a frustrating build because this old mill was downright determined to defend her right to choose to rotate. I was very surprised at how much torque was involved and how much force it took to overcome it.
I have looked at the pictures, trying to find a decent overview and nothing I have would be very helpful.
However, this thing really does work so it is doable. I'll try to get some decent pictures to show you here.
I want to go home!
Old 07-05-2016, 06:33 PM
clive's Avatar
Thanks, I guess a shot of the finished article, those who are keen should be able to work it backwards from there.
Clive
It's So Easy
Old 07-06-2016, 07:55 AM
MarkBall2's Avatar
Now why didn't I think of that?????
ID:	133417   Click image for larger version
ID:	133418   Click image for larger version
Mark
Hobart Handler 175
Chicago Electric 165A DC TIG
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Harbor Freight Tubing Roller
Craftsman 12 x 36 lathe
Papa Lion's Gate Build
Old 07-06-2016, 11:41 AM
ummmm?
I want to go home!
Old 07-06-2016, 01:11 PM
MarkBall2's Avatar
ummmm?
electric lift (head slap)
Mark
Hobart Handler 175
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Old 07-09-2016, 04:49 PM
Clive
Now Clive, surely you've been around here long enough to know me better than that.
However, I will try to be more brief than my usual.
I've been noodling around in the pictures for a couple of days trying to reorganize what my thoughts were from 2013 and '14 when I was pecking at this project.
First of all I have some Thompson linear bearings & a 3/4 inch rod from an old laminating machine or something that I dug out of a dumpster behind a print shop. I just had to try them to see how that worked.
Don't do that.
Linear bearings have way too much play in them.
Second thing, the castings on the head and on the base of these Rong Fu or Harbor Freight or Jet or whoever puts their names on these mill/drills do not have any flat surfaces that are perpendicular to the spindle. So don't think that you're going to be able to bolt any kind or right angle mounting bracket to them & have a useful basis for tracking in line with the column or the spindle.
1 - 5. So I determined that Mark has it right with making a yoke to attach to the top of the column. I made mine from a small slab of 1/2" aluminum plate that I'd had for over 20 years. First I roughed it out on the old Delta bandsaw & milled the straight edges just so they'd be smoother.
I rough cut the semi-circle on the vertical bandsaw then used a flycutter in reverse to cut to the pencil line I had guesstimated before I started cutting. You can imagine my astonishment to find that it fit perfectly to the column on my first attempt. The damned thing actually fit so snugly that it would hold itself to the column with no weight or pressure on it.
So I very gingerly milled a slot in the center of the yoke to fit over the rack because this attachment has to fit on the crank side of the head. That's where the rack is.
Then I made a "headband" to hold the yoke to the top of the column.
Name:	2014-06-12 17.24.59.jpg
ID:	133519   Click image for larger version
ID:	133520   Click image for larger version
Name:	2014-06-13 18.44.35.jpg
ID:	133521   Click image for larger version
Name:	2014-06-14 17.14.01.jpg
ID:	133522   Click image for larger version
Name:	2014-06-16 01.56.08.jpg
I want to go home!
