Old 10-17-2017, 12:56 PM
camdigger's Avatar
Roving Reporter
Default Extra quick and dirty Aluminum melter
I needed a 2 x 3 x 6" piece of stock for a project, but I don't have anything near that size. I do have a bunch of smaller pieces of aluminum I have scrounged up over the years. I have also dabbled in casting aluminum a few times over the years. I decided to try lost foam casting for the first time. The melting was a complete success. The castings were less successful, but will do what I need them to. Each pot of Aluminum was roughly 70 cu in.
The heat source is a Tiger brand propane torch that puts out 500,000 BTU. The rest is just scrap from inventory. The ingot mold is just some angle iron scraps I welded up 20 years ago.
ID:	141596   Click image for larger version
ID:	141597   Click image for larger version
ID:	141598   Click image for larger version
Old 10-17-2017, 04:01 PM
Did you use any flux in the melting process?
Old 10-17-2017, 11:33 PM
camdigger's Avatar
Roving Reporter
Not much. Just a sprinkle of KCl.
I have had good luck just remelting cast Aluminum. I've done a few with surprisingly little porosity. Extruded Aluminum is different and gives lower quality castings. Worst of all is cans and swarf, very heavy slag and poor yield.
