Old 11-06-2017, 02:59 PM
Scratch Scratch is offline
Default New Coal Forge Build! (pic heavy)
Well I recently finished up my third forge and thought I'd share the build with you all as I think it turned out pretty well. Sorry about all the pics, but everybody like pics right!?!?
Back in about 2007, I built a real nice propane gas forge for my very first forge, and while it worked well, I quickly realized that I needed something that could handle a wider piece. So about a year later, I ended up making a simple coal forge from a wheelbarrow tub and a clothes dryer blower. I figured I'd make something simple, quick and cheap... then when I get more experience and could figure out exactly what I wanted in a forge, I could build one specifically to suit my needs. Well I finally went and did it, and I took pictures too! ... Lots and lots of pictures...
To reminisce... here is a picture of my first gas forge, and also my simple wheelbarrow forge.
ID:	141845   Click image for larger version
Old 11-06-2017, 03:00 PM
Now, let's get on with the build!
I've always considered the the firepot to be the heart of the forge, so that's what I started with. I have a CNC plasma cutting table so I drew up the firepot in Corel Draw, then cut out the pieces from 1/4" A36 HR steel and welded it up.
ID:	141847   Click image for larger version
ID:	141848   Click image for larger version
Old 11-06-2017, 03:01 PM
Then I drew up an easy to replace "grate plate" for the bottom of the firpot. I was going to just weld in some bars for the grate, but thought I could easily cut a new one when it gets burnt out, and just drop it in place like this. The extra thickness will help the firpot last longer as well.
ID:	141850   Click image for larger version
ID:	141851   Click image for larger version
Old 11-06-2017, 03:02 PM
Next I drew up the floor pan and cut it out from 3/16" steel, then drew up the four sides, cut them out, and welded them to the floor pan.
ID:	141853   Click image for larger version
ID:	141854   Click image for larger version
ID:	141855   Click image for larger version
ID:	141856   Click image for larger version
Old 11-06-2017, 03:03 PM
Then I welded on some legs from 2X2 square tubing, welded some feet on them, and added some wheels on the back legs. The finished floor pan height is 32".
I tore apart my wheelbarrow forge and used the blower, tuyere, and ash dump from it since it would save time, and it already worked great. I do wish the ash dump was deeper, but I can live with emptying it more often. I also welded on some bracing straps to mount the blower directly to the tuyere.
ID:	141859   Click image for larger version
Old 11-06-2017, 03:05 PM
I was going to drill and tap some holes in the bottom of the firepot, but I couldn't find my tap and die set, so I figured out which position I wanted the tuyere, drilled some matching holes in the firepot and the flange, then cut the heads off some 3/8" bolts and welded them in place to use as studs instead. I used blue tape to hold the studs upward in place while I plug welded them from the bottom inside of the firepot. Worked great!
ID:	141861   Click image for larger version
ID:	141862   Click image for larger version
ID:	141863   Click image for larger version
ID:	141864   Click image for larger version
Here you can see a close up of them bolted together, a complete shot of my firepot/tuyere/blower/ash dump assembly, and finally with it installed under the forge body.
ID:	141866   Click image for larger version
ID:	141867   Click image for larger version
Old 11-06-2017, 03:06 PM
I drew and cut out a piece of 14 guage steel for an air gate, then welded a handle and a stop to it. CNC plasma tables sure are handy!
ID:	141869   Click image for larger version
Old 11-06-2017, 03:07 PM
I decided to weld on some bars to hold my tongs, shovel, rake, etc... from 3/8" X 3/4" bar stock. I put them on three sides since I wanted the versability to be able to use it in lots of orientations.
ID:	141871   Click image for larger version
Tags
coal, coal forge, edge metalworks, forge, scratchthejeepguy
