Old 11-06-2017, 03:08 PM
Scratch Scratch is offline
I have these openings on all four sides so I can get longer stock, low into the sweet spot if I need to, but I still wanted to be able to close the openings if I'm not using them so coal won't spill out. (also... the opening on the one end farthest from the firepot is deeper and flush with the floor pan in case I ever want to clean out the forge by sweeping rather than tipping it over)
So to close them, I made some sliding "coal gates" that can be partially or fully slid out of the way, or even flipped to the outside when I want to open them. All four of the coal gates are identical for ease of replacement.
ID:	141873   Click image for larger version
ID:	141874   Click image for larger version
ID:	141875   Click image for larger version
Then I welded in some cord hangers to hold the 20' power cable.
ID:	141877   Click image for larger version
Old 11-06-2017, 03:09 PM
I couldn't decide on where to mount the power switch since I wasn't sure which of the 3 sides I would be using as the front, so I decided to attach the switch to a movable mount that can attach to anywhere on the forge body. I also used flexible steel conduit to help protect the wires from heat.
ID:	141879   Click image for larger version
ID:	141880   Click image for larger version
Old 11-06-2017, 03:13 PM
And here it is all finished up! I painted the firepot and floor pan hi temp black, but painted everything else industrial grey since that's what I paint all my home built tools in.
ID:	141882   Click image for larger version
ID:	141883   Click image for larger version
ID:	141884   Click image for larger version
ID:	141885   Click image for larger version
Old 11-06-2017, 03:15 PM
more pics of the underside...
ID:	141887   Click image for larger version
ID:	141888   Click image for larger version
I also made a removable support extension for long stock that can mount anywhere on the forge body, and also stores conveniently on any side when I'm not using it. It's exactly 24" long and 12" wide to double as a measuring tool if needed, plus I bolted on a piece of broken measuring tape to it, for smaller measurements. Can't wait to fire it up!
ID:	141890   Click image for larger version
ID:	141891   Click image for larger version
ID:	141892   Click image for larger version
ID:	141893   Click image for larger version
Old 11-06-2017, 08:34 PM
rmack898's Avatar
rmack898 rmack898 is offline
That HURT!
That is nicely done. I can see you put a lot of thought into making everything work together.
Mac
Old 11-06-2017, 09:00 PM
Very Nice.
I will want to see how it fires up, that should be a large firepot judging from the pictures. Do you have a power hammer?
Herodotus
Old 11-06-2017, 09:26 PM
Nice work. Really like the gate idea. Consider that one stolen.
Old 11-06-2017, 09:44 PM
Nice work. Really like the date idea. Consider that one stolen.
Date idea?
Tags
coal, coal forge, edge metalworks, forge, scratchthejeepguy
