Old 11-27-2017, 07:06 PM
Default Lathe threading...
First day on the job and I am shadowing the junior machinist. We had to make a replacement to shaft for a hydraulic cylinder. Turn one end 7/8” shaft down to 1/2” dia. 1 1/2” length. And then thread the end for 20 tpi for 5/8” long.
All seemed straightforward enough til he started threading. I was taught to angle the compound slide to 29 degrees and use that to feed in. Use the cross slide to back the cutter out at the end and then move carriage back for next cut, feed in cross slide back to 0, and adjust the compound for next cut.
We are using quick change tool posts with threading insert tooling. This is all new to me now. The compound is set parallel with the ways, and seems only to be used to sneak up on shoulders when done with carriage feed. Only the cross slide was used in feeding the threading tool bit in.
Later, that was the last machining job of the day, so I was told to go practice on my lathe and turn something to learn the lathe controls. I took the old shaft and machined the threaded end. I got the threads to work, but was not happy how they actually looked. They seemed off, as one side was wrong angle. It may have been that I did not verify that the threading tool was perfectly perpendicular to the shaft and I think the compound is off slightly. Previously they mostly used the lathe to chuck up parts to clean up with Emory cloth and or use spray metal weld build up on certain few jobs per year. I had to clean up the thread dial to be able to read it, so I know it has not been used for threading in a while.
So my question is, is it Good practice to only use the cross slide feed when threading using threading insert tooling. It seems to me that the reason I was taught to use the compound slide was so you only cut on one side of the hand ground tool but mostly, and if you were off a little in the grinding of the 60 degree cutting bit, it would not make as big a difference in final threads. I would think that the insert tooling is ground to more precise angles vs hand grinding a tool bit and can handle taking chips out on both sides of the bit at once?
Now on to do some research on my lathe at work. It is a Summit. Will have to get actual size later.Click image for larger version
Old 11-27-2017, 07:12 PM
New boss asked how first day was going and I let him know what I was doing. I mentioned that I was having to borrow quick change tooling from other guys lathe, and I would have to adjust the height nuts for my lathe, and he thought about it, and said he will probably order me a new quick change tool post and new holders since he was told that this one is wearing out. The handle to tighten is turning more that it should because the gears inside are wearing out? At least that’s what I was told by Co workers. So I might come in tomorrow and have new tooling to work with. big change from my old job in this way.
I was starting to design a hammer to make. I figured if they want me to make some chips to learn the lathe, might as well make some useful tools in the learning time. Want to make a hammer with different screw in heads. Figure one brass, aluminum, nylon, and maybe a lead one. Anyone have any leads on plans for such a hammer?
Old 11-27-2017, 07:13 PM
I was taught the way you were taught and for the same reason.
When you say insert tooling, do you mean a multiple thread laydown
insert ? Or just a single "V" ?
BTW on such a small thread (that looks like a common size)
They don't have a die head laying around ?
Old 11-27-2017, 07:24 PM
Probably does not help much but, I do my threading just like they are doing. Just seemed easier in the set up to me. You do have to have it perfectly square to the part this way. I have done it the other way, just like this way better.
Old 11-27-2017, 07:57 PM
Here are some hammers I made
Old 11-27-2017, 08:06 PM
Either way will work, especially on small threads like a 1/2-20.
Verify your bit is square to thebwork with a 60 degree gauge (I always called them fishtail gauges, can't remember the proper name!)
Doing it with the compound parallel, lock the compound and just use the cross slide for depth. Use cutting oil, and don't be afraid to run a little faster on the rpm then you would with hss if you can.
As you get close to final size, taking lighter cuts should help on the finish.
Old 11-27-2017, 08:51 PM
Single v bit. Three cutting edges on insert, dull one and rotate as needed.
I think they will cut more with lathe just because? This one could have used a die just as easily. I guess sometimes, we may make special diameters but still use a common fine thread. They didn’t worry about measuring with wires though. Just cut Til they look close and start checking the nut going on. When it threads in easy, your done.
Old 11-27-2017, 08:55 PM
This is where I am thinking I messed up. I did not verify that the bit was square to the work. I did take lighter cuts near the end though. Thanks for the reply.
Old 11-27-2017, 08:58 PM
Thanks for the reminder of this thread, Ted.
Old 11-27-2017, 09:00 PM
Another thing to watch is the tip on inserts, they often have different radii depending on the tpi that you're cutting. Bigger radius for a 'coarser' thread.
Double check the height of the tool to centre too.
