Old 12-06-2017, 08:32 AM
Default Propylene: Foundry and Forge
The Spawn of Shade, Matt, has been working on a foundry this summer and
now is interested in building a forge. So we were using some old LP gas I
have laying around. We use a lot of LP and the small cylinders get too cold
and we loose pressure so going with Propylene and a large cylinder will solve
some of those issues. Hotter burning gas and better supply pressures.
Do any of you Blacksmith guys use Propylene (Propene) for fuel gas in your
forges or foundries? What is your experience?
I picked up a 105# cylinder yesterday.
Old 12-06-2017, 12:34 PM
You could always do what a scrapper up here did on his aluminum furnace. He would put a couple weed burners on the propane tank to help with gas evaporation. Interesting to see burn marks on the big propane tanks.
Old 12-06-2017, 12:49 PM
Interestingah !
Having never the need, I just now read the Wikipedia article on it.
So it's basically "de-hydrogenated" propane ?
And you still store it under pressure as a gas ? Much like propane ?
But how does it fix the freezing up with large pressure drop problem ?
Old 12-06-2017, 01:22 PM
Yeah, I have no desire to win a Darwin Award.
Old 12-06-2017, 01:34 PM
Interestingah !
Propane is C3H8
Propene is C3H6 (aka propylene)
Propyne is C2H4 (but has the same issues as acetylene aka as Ethyne)
There are 2 benefits from going with propylene that aid in solving "freeze up"
issues. Simply the first is it is a 105 lb. tank with a much greater thermal
mass. A 100 lb. LP tank would go a long way to solving the same issue. But
also Propylene carries almost the same energy as acetylene so I will be using
less gas for the same BTU output so, less gas means it will take longer to cool
the tank to the point of "freeze up". Technically the liquefied gas in the tank
never freezes in either case but the temperature get low enough that the
boiling of the gas off the liquid phase is so slow that it cannot keep up with
demand. Also the price I get from my LWS (who takes damn good care of
me) cannot be beat. And they stock Propylene in 105 lb. tanks and not LP in
100 lb. tanks.
Note: The really energy in is breaking Carbon-Carbon (C-C) bonds when
burning fossil fuels. Methane is the worse for energy production and coal
being the best. Acetylene even though it only has 2 carbon atoms has 3 C-C
bonds. Propylene has 3 carbon atoms and 3 C-C bonds.
Old 12-06-2017, 06:12 PM
Shade, I have a Mapp/Propylene Victor cutting torch tip NIB if you want it. I use Acetylene for my torch and propane for my forge and have no plans to change. I think it was a $40 tip that was mis shipped to me. Let me know if you want it.
Old 12-06-2017, 10:43 PM
Thanks for the offer!! But my torches are all Smith, so it wont do me any good.
Old 12-09-2017, 12:58 PM
I've never ever used it or been involved with a shop that did. Seems besides Acety I might have used Mapp two or three times for that fact.
I do use LP for my forges a few heating tips/rosebuds and with respect to loss of pressure and cold, I can heat my bottles either by hot water, continuously hot, or a heated enclosure for my 300 gal tank outside.
I've seen one bloke having a coil of 1/2" copper pipe/tubing that would cover the small bottles from top to bottom and run hot water through this to keep pressures workable. He'd turn the water on drop the bottle inside the coils and cover with a blanket to warm his bottles while in use. Worked well.
Old 12-10-2017, 09:17 AM
Brian C.'s Avatar
Brian C. Brian C. is offline
Director of Security
I saw a factory rep do a weekend propylene demo at Quad State one year. Cut like a champ. Other than that I have no info.
To keep my small propane tanks from freezing up, I clamp them down in a big galvanized wash tub of hot water. Works great.
Millermatic 211
Harris oxy/act.
2 propane forges
147 lb. Peter Wright anvil
Old 12-10-2017, 05:12 PM
from what I understand just switch to a larger capacity tank will help with freezing..
The polypropane is more expensive and is one of the reasons I don't know of anybody using it..
Again, I like to use coal for most part except with production oriented work..
_________________
Jennifer
My google+ page
DoALL 36"
