Old 01-03-2018, 09:46 PM
Funny part of that ad/picture? That’s not a surface grinder, it’s a small tool and cutter grinder. Those I have dealt with from Cincinatti, and have even moved a couple of them.
Old 01-03-2018, 10:35 PM
Riverr1 Riverr1 is offline
http://www.cinmac.com/SurfaceGrinders/Specs6x16.html
Sorry, didn't look that closely at it. Even so, most tool grinders I've used that have a table can be used as surface grinders. Granted, some require an attachment.
Old 01-06-2018, 08:44 AM
Been doing some research the last couple days while the cold weather has been here. Looks like the oil pump for the Harig grinder is a Bijur 32671. Not a cheap item, most online prices seem to be about $360 US. At least I have better specs and options to look at.
Old 01-06-2018, 10:02 AM
Can the pump be rebuilt? Is there a rebuild kit?
Old 01-06-2018, 11:58 AM
The pump isn’t there, some where along the line it was taken out and replaced with a one shot oiler. Seems it’s a common occurrence, but sadly it’s not a fix.
The ways on these are setup for constant oil flow, as they ride on the oil, instead of ball bearing races like a lot of grinders.
Old 01-07-2018, 02:13 PM
Maybe use a power steering pump
Herodotus
Old 01-08-2018, 07:21 PM
Good idea and there are plenty of electric ones in the salvage yards now.
Old 01-12-2018, 01:31 PM
Well, the mill and grinder followed me home today. Likely going to simply re-arrange things so that I can park trailer and machines in one end of the barn for now.
Of course it’s a wet miserable kind of day, so sprayed them down with rust preventative and quickly wrapped what I could. Wiped the water off when I got back to the farm and tarped them for now.
Once they’re under roof, likely later today, I’ll dry them again and oil them for now.
