Old 12-25-2017, 12:25 PM
biker55's Avatar
biker55 biker55 is offline
Default bench grinder info
Hope everyone's having a good holiday so far. anyway, finally unboxed the bench grinder which I purchased a year ago. never had the need for one until my neighbor told me that it would be very useful for certain things. like sharpening knives and stuff. well the thing comes with two sharpening stones. one is composite and the other is aluminum oxide. which one do you use to sharpen knives with? I also saw a bunch of you tube videos and they're very conflicting as to which direction the blade should be facing. some show the edge of the blade facing the rotation of the stone and others showing the blade facing upwards against it. Thanks
Old 12-25-2017, 12:41 PM
I have seen them both ways too. Cutting edge away for the stone rotation will leave a burr on the blade. Opposite, very little burr. What grit are the wheels?
I tend to use a hand stone most of the time since it is easily controlled vs a spinning stone. If you are putting a new knife to the wheel to form the edge, I would use a grinder too. Just not for touching up the edge.
What are the # Grits of the wheels?
Old 12-25-2017, 02:29 PM
biker55's Avatar
the manual says 36 grit. Thanks
Old 12-25-2017, 03:26 PM
36 grit is a bit rough will take a lot of meat off the edge
I know a knife maker here and he only uses narrow belt sanding machines has three with various grit belts but that may be only part of the proses an i haven't see him using a bench grinder with a 36 grit wheel so all i can tell ya
And grinders don't work for my flint knives they sort of defeat the purpose
..Randall.......Peace!
do nothing." -Edmund Burke-
Old 12-25-2017, 03:52 PM
I would change to a 100 and a 220 if it were me.
Old 12-25-2017, 05:26 PM
I would never sharpen a "good" knife on a bench grinder. Maybe if you're re-shaping or something but for actual sharpening a powered wheel is too aggressive...
Old 12-25-2017, 06:50 PM
biker55's Avatar
it's a variable speed grinder. I'm using it to sharpen my first home made knife. I'm not a professional at anything. but like to try new stuff. one day I was off and got restless. went into the garage, saw some stuff lying around and said hey! why not try making a knife! never sharpened a home made knife before. the blade is kinda rough. just seeing if I can do this. Thanks
Here's a pic.
Old 12-25-2017, 11:45 PM
Here's a pic.
Dang 55.... That knife looks huge could be just the pic and my depth perception, but i seen that and think meat cleaver.....
but not bad for a first knife not bad at all
Old 12-26-2017, 04:55 AM
gimpyrobb's Avatar
I agree with others, 36 grit is way too aggressive to use for sharpening.
