Go Back   Shop Floor Talk > Welding and Metalworking Forums > General Technical Information
JR Welding Tools
Old 04-20-2006, 11:16 PM
Project Manager Project Manager is offline
or Project Empress
Default Coping Tubing
The Notcher by dmerd
Coping tube with a Chop Saw by Chumly
(and it includes this little calculator by j13l who pmailed it to me earlier in April but I wanted someone to post it before I linked it here)
Has anyone ever used this software to layout angles for ...Q, by Steve V.......Pipe Joint Template Software
Angle Calculator Thanks to j13l!
Another Calculator posted by Pile Buck
Old 04-28-2006, 12:13 AM
or Project Empress
Default 3 Phase Converters
Phase Converter Question by 7018
3 Phase Rotary Converter by cutter
Three Phase Rotary with Auto-start Article posted by CharlieC
Dan's RPC Build by Lu47Dan
While I wait for ........ by Lu47Dan...... clutch assembly for the RPC.
Installing 40 hp Rotary phase converter........by allessence
Old 06-27-2006, 01:37 PM
or Project Empress
Default Ok Kids, Try this at Home.
Home or Shop Built Vehicles & Conversions:
My home built scooter build from 1951 plans ....by Gungatim
First post and a small project. Go Kart ....by UglyWelds
Buggy by Camaro Zach
Truggy Project by stomper4x4
Old 07-16-2006, 10:16 PM
or Project Empress
Default Trailers
<> Trailer parts & information
Building a small trailer ..... by Vernon
I need to build a tilt bed trailer .....by metalmole ... pictures
Scarab 2600 boat and trailer refit/rebuild ....by Ed
Finished one of many.... ......by camdigger .......dump cart
Hay Trailer Build .......by milomilo
The throw together wood trailer .........by engineman56
tongue extension .........by fuel749
Drop Bed Trailer Design......opinions.........by dta84.........Discussion
Trailer Snatch by Photomask
Dump Trailer by randy_m
Got a new motorcycle trailer by RLJ3RD Beautiful Miller blue!
Four threads by jksweld:
Finally Welding Trailer Pics
Welding Trailer: Air Compressor mounted to welder motor and more.....
Welding Trailer: BIG air tank mounted and plumbed
Welding trailer update
Old 07-16-2006, 10:30 PM
or Project Empress
Default Tables, Benches ~ Indoor or Outdoor
Adjustable work table .......by NOBLNG
Chainsaw Sharpener Auxillary Bench. ....by Lu47Dan
Work table extensions....found by mudbug
Child's Folding Workbench .....by Stephenw
Ode to a wine rack...'cept it's a coffee table by dubby
Found my other table by dubby
Three Leg Bench by getatorch
Tile Tables by getatorch
another tile table by scott-n-montana
A Table is born by Broccoli
Table #2 Plant Stand
Table #3 All 3 posted by Broccoli1
New Tables by rickairmedic
Vise stand........By getatorch
Old 08-16-2006, 10:52 AM
or Project Empress
Default Wood Stoves, Smokers & BBQ's
Fire Pit Grate Build .........by NC Fabricator25
Catwalk Fire Grate .......by Cutter
The Semi Rim Stove ...........by engineman56
Wood Stoves Thread started by Pile Buck
Woodstove Thread started by Dman033189
Burner/boiler thing ...by AJinNZ
burner project gas grille ......by Scotts
BBq Grill .....by David R
Texas Wok by Photomask
Grill/Fire Pit by PhotoMask
Grill/Fire Pit by Photomask
New Mobile BBQ by fatfrank
belgium (bbq) by niels
A few BBQ pit pictures by jpill
Bbq by Bender
BBQ Grill for a steak or two by justweldit41
Campfire Grill by dubby
Pig Roaster by hvac81
Smoker trailer .......by getatorch
BBQ Smoker is completed by ace4059 & fatfrank
BBQ - Smoker By Charlie C
Vertical Smoker by Bender
Old 09-04-2006, 02:21 PM
or Project Empress
Default Cable and Hose Reels, Hangers & Racks, Pallet Carriers
Ext. cord reel ....By nctox
Cable reels 2.0 ....by RogueWelder
Cable Slider by Photomask
Folding saw horses posted by 7018
New Trailblazer Carrier by DDA52
Pallet Cage for Welder by Jack Ryan
Old 09-22-2006, 10:41 AM
or Project Empress
Default Machine Shop Projects
Lack of balls ........by Ironman .....Lathe ball turner
Spindle Lock for the Grizzly G3103 Mill ......By chengdave3003
Riser Block For a Grizzly G3103 Milling Machine .......by platypus20 ....Mill head.
6X26 Riser Block .......by Charlie J ...mill head
Shirley's Suit of Armor .....by dubby ....CNC Sherline lathe enclosure.
Drill Press lift .......by brucew
Drill Press Table Drive Experiment .....by Cutter
Fixing the drill press vise .......by Cutter
Vortex Generator (cutting tool cooler) by digr
Hand Tapper by digr
5C collet chuck ......by precisionworks
___
Clausing Lathe Chuck Retaining Ring Spanner Wrench. .......by Lu47Dan
Drill Press Vise by digr
Parts Washer by digr
Pipe Stands by digr
Vee Block & Clamp by digr
Center Finder use with Vee Block Clamp (above) by digr
The knob by digr
Drill Press Vise #2 by digr
Repairing a Broken Shaft by GWIZ
I built a line borer ! by BBchevy396
Combination Line Boring Rig and Welding Table Build… by TriHonu
My Clock by metalneck78
lay out help by RED caddy
Vee Block by digr
Hoist worm gear fabrication ................by toprecycler
Good 'nuff stuff .............by camdigger.....Various machining projects
knurler, D profile bits and reamers, Taig steady rest and tool posts, flycutter
The Harbor Freight Toolgrinder thread by Fla Jim
DRO's Digital Readout's
Mini DRO ..... by Ironman
Installation of a DRO on my M-Head Bridgeport Mill. .......by Lu47 Dan
Another cheap DRO project .....by dubby
DRO installation on tail stock .........by precisionworks
Added a DRO ......by Hylander
Mildred Does Digital ....by Cutter......Mill/Drill
Grizzly T21577 0-6" Digital Quill Scale .........by platypus20
Bridgeport Quill Caliper DRO? ....by Randyjaco
DRO's Digital readouts ...by GWIZ
Milling and Projects.
mill from a drill press. .......by Hobweld
Drill press to milling mach. ......by shopsmith
Power drawbar ..... by rmack898
Vee Blocks .....by Cutter
Walnut Cracker Machinist Version .....by atwatterkent .......plans
MLA Die filer kit .......by rmack898
Nice project for your mill ......by monte55 .....(mill) table-mounted vise.
Milling attachment for South Bend 9A .....by shopsmith
Milling Adapter Plate .....by platypus20
Cutting new gears on a lathe .....by MarkBall2 ....... with a Lathe milling attachment.
Mill Drill Spindle Lock My Version ......by jamesemery728
Getting Dirty with Mildred .....by Cutter ....... Lathe carriage stop.
Lazy Susan .....by digr...Collet rack
One Shot Oiler ...........platypus20........for milling machine
Jib Crane ..........by platypus20........Mounted on milling machine
Making a Toolpost Grinder by GWIZ.........For a Lathe.
Making a Face-Plate by GWIZ.....For a Lathe.
Universal bevel Cristmas gift for Trevor ........ by rmack898
Lifting Mildred's Spirits ...... by cutter
How Mildred Got Her ..x drive back. .....by Cutter....mil table power drive
mill table drive .......by arcflash
Drill-Mill Table Drive by Cal_W
Speed Reducer by digr
Chord Depth by irnsrgn
Download site for Bridgeport Full Manual (revised 2005) posted by Fla_Jim
Lathe projects.
Making Dickson style quick change tool post holders ...by Davo J
Die Holder ...... by clive
Brass Collet Adapter ....by Cutter
Taper attachment home made ......by aametalmaster
Clausing V-way angle, its is time to build a few attachments. .........by Lu47Dan ...Indicator mount and steady rest.
Swinging Threading Tool .....by platypus
Tailstock Mod 7x lathe ....by dubby
Drill Attachment for Charlie .....by Cutter
Reversed live center. .....by aametalmaster
Steady Rest for the 13x40 ......by J.Ramsey
Joined the Gear crowd ........by Norm W.....Cutting a gear.
Cross drill .......by digr
Pulley .........by digr ...also pdf on how to.
Taper attachment home made ..........by aametalmaster
ER40 collet chuck for lathe ......by aametalmaster
Some pulleys. ................by aametalmaster
Bull nose center made. ........by aametalmaster
Big lathe faceplate made .........by aametalmaster
My Daughters ring ..... by Barn Owl
Black powder mortar ......by Fla Jim
1835 Mountain Cannon ....by Cavalry
Project: Lathe Tach. Lots of Pics HS needed ......by SlimJim
Lathe dog .......by digr........always in balance.
Lathe pedestal .........by Ironman.........riser in place of compound
Offset center .........By digr
Chuck Key by digr
Tool Holder by digr
4-Way Tool Post Tool holder by digr
Boring Bar Holder by digr
Custom Boring Bar by Jeff
Drilling the Boltholes in a New Backplate as suggested by GWIZ, thread by cutter
Lathe Flat Belt Replacement by REDcaddy
Thread cutting depth by irnsrgn
Machine screw sizes. by irnsrgn
Making Long cuts on a lathe by irnsrgn
Colet chuck...............by digr
steady rest centering tube by Barry Milton
Steady Rest by digr
Steady Rest Indicator posted by digr
Sheldon Steadyrest super build project by Cavalry
Quick Tool Post Grinder by WP88
Internal Grinding Arbor for TP Grinder- Simple soution ...... by Randyjaco
Homebuilt Tool Post Grinder .....by engineman56
Cutters Atlas Lathe Series.
Atlas babylathe ..........................10-16-2004
Atlas Baby Lathe Resurrection........11-23-2008
Drilling a New Back Plate................02-28-2009
Fun with Charlie 4-jaws.................03-01-2009 ....Diamond Dresser.
Charles Atlas goes to the Movies ....04-29-2009
Charlie Babylathe Gets Balls............06-27-2009 Lathe ball and radius cutter.
The Ringo Challenge......................07-09-2009 Lathe milling atachment one.
The Platypus Challenge..................09-28-2009 Lathe milling attachment two.
Dayton 90v dc Motor for Charlie .......03-23-2013
Old 01-05-2007, 07:49 PM
or Project Empress
Default Lawn & Garden Projects
Carts, tractors, mowers, trailers, etc.
Link Outdoor Power Equipment Information ...found by Lw Hiway
Get the weeds out! Garden tool. .....by allassence
Building a yard rake
.....by Vernon
This weekends project .......by jb-mck ......tractor drag, leveling dirt, smooth out ruts.
Lawn Tractor Bumper .....by ddoering
Lawn sprayer ......by digr
Simple Disc Hiller ......by brucew
ZT's, Unfair to OLD FOLK...news at 11 ...by LW Hiway ....adding a hand rail
JD 317 Project ..........by Tony T......Overhaul
Yard Sprayer Mod ...........by PA Weldor
Inspired By Cutter's "White Trash" by Troadster
Garbage/Yard Cart by rmack898
ATV Hitch by rmack898
Lawn Sprayer by tigman250
Rear Carrier for Atv by Burnham
Weedburner Cart by cwgrizz
Weedeater Rack .......by Cutter.
Lawn tractor adj. hitch. .......by LW Hiway
Shredder Mulcher Question
Shredder Mulcher......by Bubba.
cutter's little tractors
Tractor (Ol' Yaller) 4-22-06
Little Tractor Firewood Hauler 9-26-06
Yaller Tractor Carb Upgrade 6-25-07
Ol' Yaller Brake Job 3-03-08
Ol' Yaller Rides Again .....by Cutter 8-22-11
cutter's White Trash Series - Forksnatch
More Tractors 9-24-06
Whiteboy Gets a Cherry Picker 11-18-06
Still More White Trash 2-18-07
Texas WhiteTrash Forksnatch - (the first movie) 4-3-07
Born Again White Trash 10-3-07
WhiteTrash Firewood Basket 11-13-07
Firewood Rack 11-19-07
Quick Connects for the Whiteboy 12-19-07
Whiteboy Gets a Morale Boost 1-28-08
Whiteboy Threw a Shoe & Got a Pair 7-26-08
Judge Bob & the Whiteboy 6-16-09
Old 02-08-2007, 02:07 PM
or Project Empress
Default Toolboxes
Imagineer's Toolbox drawings and tool box by imagineer
fabricators tool box by tigman250
