JR Welding Tools
Old 10-07-2017, 08:35 PM
Worked some more on things today. I cut a couple 1/2" slices off a piece of 1-1/2" square tube and tacked the ends of four 6ft pieces of #4 rebar to the corners to make a drop-in rebar assembly for the post then filled it with sakrete. We also put some vinyl numbers on the mailbox door went on a lot less trouble free than I expected (worked sort of like decals) Closing in on completion before the plows roll out. It could happen for the first time Mon. depends on how fast the snow comes down.
