Old 05-08-2015, 02:34 PM
Default To fix an error
I made a mistake. :-) made a device in two parts that should have been one.
Now have to try and put them together. The following pix. will explain it better than any words I can come up with. The pins was the first thing that occurred to me but any suggestions will be gladly considered. (but note the "no welding" admonition) :-) There shouldn't be any "twisting" to speak of but that is only
obvious to me problem with the pins. Questions that do occur is the length of the pin/pins adequate. Can't be any longer due to intrusion into hole and other features.
Thanks for any ideas.
...lew...
Old 05-08-2015, 03:33 PM
Drill and ream undersized holes to match.
Use oversized dowel pins with Red Loctite.
Gotta ask, why no welding?
Old 05-08-2015, 04:53 PM
I don't do it and it would require too much clean up which I don't like to machine. So something like a 5/16 dowel pin you think would hold it?? or even 1/4. The thing that worries me is the only 1/2" depth. Do you reccon I can press with a .001 interference or just how much ??
...lew...
Old 05-08-2015, 05:02 PM
digr digr is online now
One 3/8" dowel with two 1/8" pins
Old 05-08-2015, 05:43 PM
JBFab JBFab is offline
I was thinking the same thing, except with tapered pins and some goo like Ron was referring to.
Old 05-08-2015, 07:32 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Lew, a couple of pins and glue it together with 15min set Fuzor from Lord Corp. The pins will help prevent twisting and the Fuzor will hold it better than Loctite will. I glued a tv stand together with fusor for a freind as it was always loosening up. It is still as solid as of last fall when he moved the last time.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 05-08-2015, 11:45 PM
Dowel pin.
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=944000
Reamer
http://www.use-enco.com/CGI/INSRIT?P...PMPXNO=2614192
Old 05-09-2015, 12:15 AM
Well I don't know if this helps, but I have made a double ended electric motor out of a single shaft this way.
I machined a 5/8" shaft and stepped down to 5/16" for an inch, and threaded the stub NC thread. I drilled and threaded the back end of the motor shaft for 5/16NC thread about 1.25 deep. Then fluxed and tinned the threads with solder, heated gently and screwed them together and let it cool. Done.
You could use allthread rod and do this.
Or, because of the short depth (1/2")use a inch long setscrew and thread them together with permanent locktite.
Old 05-09-2015, 09:37 AM
out of a single shaft this way. I machined a 5/8" shaft and stepped down to
You could use allthread rod and do this. Or, because of the short depth (1/2")
If the part was round and not rectangular that would be ideal. But clocking
these parts so they line up when torqued is a real challenge, possible but a
challenge. I like your soldering solution vs. Loctite.
Old 05-09-2015, 09:55 AM
I think the clocking is an "insurmountable" problem. :-) At least for me.
A single pin is going to be "just barely possible" to clock the two while doing the press. May have to add a second smaller one to be safe. In any event come Mon or Tue at the latest I'll have to give it a try on one sample. :-)
Have 6 total to do. :-(
...lew...
