JR Welding Tools
Old 08-25-2005, 01:08 PM
NavyGuy's Avatar
NavyGuy NavyGuy is offline
Send a message via Yahoo to NavyGuy
Talking I'M STOKED....My first TIG welds!!!
Howdy y'all....I had my first "real" TIG lesson today at the welding shop I work at and wanted to see what you guys think of these. The owner of the shop gave me a 30 min lesson and then turned me loose to weld up some fittings on a pneumatic chamber that goes in a new tool that we are fabricating. The pics below are actually my second attempt....on the first one I got crazy with the pedal and blew thur the side of one of the tubes! These welds have to be air tight to hold the pressure...I'll find out tomorrow if any of the 15 I did leaks. So do me a favor...look at the pics and tell me if ya see anything wrong...TEAR'EM UP GUYS...thats the way I learn...btw I already know that I need to work on my "stops"...I keep gettin a bump of metal when I finish the weld and break the arc. Any tips would be greatly appreciated. The first pic is of 3 of the air chamber tubes...hopefully no leaks!!
Thanks y'all,
Rod
Name:	Tig Weld 1.jpg
"Failure is NOT an option"
"If you do not want to stand behind our troops, please feel free to stand in front of them!"
Old 08-25-2005, 01:09 PM
NavyGuy's Avatar
Here is a second close up up pic of one of the welds.
Name:	TIG Weld 2.jpg
Old 08-25-2005, 02:00 PM
SlagKing's Avatar
SlagKing SlagKing is offline
A Man for All Reasons
Very nice!
Mystic Seer, Pat.Pending Director of Pillage and Rymed Whimsery
Sir Slag the Seer
Old 08-25-2005, 02:06 PM
wayne64's Avatar
wayne64 wayne64 is offline
Default Three things I'll mention
First is good job on first starting out in the Tig way. The second is with a foot pedal I always backed off the amps just as I was starting the overlap and walked the puddle off to the side of the bead, as we called it "tailing off". I think I see alittle undercut in the second photo, but my eyes are shot so I'm not sure. Were you using a back purge? The reason I ask is the weld may not leak and look good but on certain jobs sugar is a no-no.
Old 08-25-2005, 02:07 PM
fatfrank fatfrank is offline
Pit Boss
I'm not a TIG welder/or, but I can't tell if its the pictures or are the welds convex? It may be the picture, but are you just doing fusion welds or are you using filler rod? Looks like you have a nice steady hand either way.
Old 08-25-2005, 02:28 PM
texrednek's Avatar
texrednek texrednek is offline
Still on Ritalin
Send a message via Yahoo to texrednek
Rod, you mentioned a bump at the end. Cant see it to well, but id think its porosity. I think you may be bringing your torch up too fast at the end of your weld. Argon is light so when you finish your weld hold your torch there lil longer and just pull the pedal all the way back. Tell me if this does change things. lookin good friend though. A fine tig welder youll become
Old 08-25-2005, 03:23 PM
b-footn's Avatar
b-footn b-footn is offline
Yes girls, he's single!
I see your first mistake. You forgot to take a picture of the beer bottle next to the weld
Old 08-25-2005, 06:15 PM
rickairmedic's Avatar
SFT HVAC Guru
Rod I'm not a tigger yet either but from what I can see it looks like three stacks of dimes in circles too me for the most part did see the bumps you were talking about in the first pic and am thinking maybe back off on the peddle at the end and let the gas purge a second before pulling off .I do think for a fist time though they look awesome DUUUUUDE .
Rick
Old 08-25-2005, 06:21 PM
houlibar's Avatar
houlibar houlibar is offline
Lord of the Reins
Thumbs up
Nice work Rod! You caught on fast! As fatfrank said, it sure looks like you have a steady hand. Maybe we should call you "slowhand"!
I see the little bump you are talking about. Well at least that looks better than the wormholes I was getting! Fixed that by letting off much slower on the pedal.
Okay, here's the only advice I've qualified to give. Since you've been arc welding and grinding a lot now you're probably pretty used to look'in through cruddy window glass. Replace your clear cover plates and get rid on all those scratches and smoke stain. It's like going from a black and white to Cinemax, LOL!
Don'tcha just luuuv TIG, Rod?
Old 08-25-2005, 08:37 PM
NavyGuy's Avatar
Howdy Chris...thanks fer the advice..and the complement..you know I'll try and give it hell!! I'll try to pull the pedal all the way back and let the gas flow fer a couple of seconds before I lift the torch when I try it again tomorrow.
Thanks again Buddy,
Rod
