Old 09-20-2017, 12:39 AM
Gadgeteer's Avatar
Default Technical Help Please
I'm building a keg lift for a local brewery, and am at the point where I need to form a loop in some vinyl coated cable by swaging the end to the main. I don't know if I should remove the coating before swaging, or just swage with the coating in place. Loop will lift a full keg, weighing about 145#. Wondering what is the common procedure. Thanks for info.
Old 09-20-2017, 02:36 AM
TEK's Avatar
TEK TEK is online now
I would remove the plastic and swage to bare cable.
You might get away with swaging on plastic for a little while but eventually the plastic is going to come apart and then someone gets hurt.
Get down to the base material, you never want to crimp on a coating that could break apart and then you have a loose swaged loop. Not good. ..
-----DozerDan
Old 09-20-2017, 05:20 AM
AussieTom AussieTom is offline
+1
Sent from my SM-G900I using ShopFloorTalk mobile app
Old 09-20-2017, 11:13 AM
What is the loop for and why plastic covered cable?
Old 09-20-2017, 11:35 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
remove the plastic and put heat shrink on last.
Old 09-20-2017, 12:09 PM
Use stainless cable and forget the plastic
Old 09-20-2017, 02:20 PM
I needed to make loop ends for tool boxes on a few large industrial machines.
Owner wanted completely covered cables with the plastic intact after swaging.
I told him that the plastic would lessen the grip of the swage process, so my suggestion was to remove that much plastic/rubber coating, crimp and dip/paint another rubber coating on the bare material.
As good as it gets.
Old 09-20-2017, 02:44 PM
gimpyrobb's Avatar
I too, wouldn't trust the plastic.
Old 09-20-2017, 05:51 PM
kbs2244 kbs2244 is offline
It hiway's way.
Old 09-21-2017, 02:00 AM
Gadgeteer's Avatar
The loop runs through the eyebolt, attached to the traveler that lifts the keg via a winch. I've noticed that some exercise apparatus use coated cables to lift weights, and just liked the appearance. But, function is always number one, so I'll dump the plastic, based on comments received.
