Old 12-06-2017, 11:04 AM
It is important that the bends in the plate be parallel. To help ensuring this, I will add a series of notches with a .125" radius along two opposing edges of the plate. These notches will be spaced 2" apart.
The notches will index with a detent locator on each end of the tool. Below is a picture of the detent locator with the 1/4" detent pin removed. The compression spring can be seen inside the counterbore.
We are Borg but we don't know it.....yet. We are being assimilated but we don't know it.....yet. Resistance is not futile.....yet. Are you and your children "connected".....yet?
Old 12-06-2017, 11:39 AM
This will make a beast of a roller compactor.
Nice work getting it up and running.
Old 12-06-2017, 11:57 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
What you want is called a sheeps foot..Easier to buy than to make..
Old 12-06-2017, 04:51 PM
But much less fun!
For me "Easy" is a concept that is often overrun by "What if".
Besides, I will have a unique convertible roller, I have not seen a tow behind with removable pads.
Old 12-07-2017, 07:47 AM
This is the first of eight plates that I am adding notches to. I took advantage of the T slot that Bridgeport provides on the front vertical surface of their tables by securing two locators to it. I am plunge cutting with a 1/4" end mill. One edge has been done.
Old 12-11-2017, 07:48 AM
The tool being used in the press. Did I mention that it was made from scrap pieces? Once I figured out a few quirks I was able to complete one plate in about 15 minutes?
Old 12-11-2017, 10:24 AM
I used the same method to make the curves in 1/4" x 4" FB for my trestle jacks. Worked great for me.
Old 12-12-2017, 07:01 AM
This was my first time bending like this. I could not be happier with the results. I Wonder if this process has a name.
Old 12-12-2017, 07:12 AM
The plates were slightly over bent. I used shims inside the die to limit the amount of travel but I was unable to get the correct thickness. adding a piece of sheet metal.030" thick resulted in an insuficent bend.
Old 12-12-2017, 07:43 AM
JohnBoy's Avatar
JohnBoy JohnBoy is online now
Director of Languages
I dont think you could hope to get much closer than that, looks great. If you bolt in the middle first before drilling for the edge holes you should pull it in easy
Although...... you're planning on welding lumps/pads onto the plates? which will pull them in the weld. is there a way of figuring the curvature needed starting out to pull the plate back to the finished curve, now that'd be cool
