  #61
Old 01-08-2018, 08:17 PM
I used 1/2" round to fill the gaps in the ends. I used a magnet to locate the rods.
We are Borg but we don't know it.....yet. We are being assimilated but we don't know it.....yet. Resistance is not futile.....yet. Are you and your children "connected".....yet?
  #62
Old 01-08-2018, 08:21 PM
I cut a chain link and welded it on.
  #63
Old 01-08-2018, 08:26 PM
After removing the pinch bolts. It it much more flexible than I thought. You can see that it did spread some but I think I will be able to squeeze it back with the cable puller wrapped around it.
  #64
Old 01-11-2018, 06:29 PM
That kind of surprised me. Never would have expected that. I figured with all the welding it would shrink some.
  #65
Old 01-11-2018, 06:39 PM
It did shrink, each half is shorter
  #66
Old 01-13-2018, 07:59 PM
Indeed!
The pinch bolts had more tension after welding. I had to apply far more torque to remove them than I did tightening them. One of the nut plates threads could not take the load. The threads have deformed and I cannot remove the bolt with my 1/2" drive tools.
  #67
Old 01-14-2018, 02:09 PM
Luckily I had unscrewed the bolt enough to fit a blade before it stopped turning.
I'm using a sawzoff (that's what I call it because it is not a Sawzall).
  #68
Old 01-14-2018, 02:13 PM
The remainder after cutting it with the sawzoff.
  #69
Old 01-15-2018, 08:02 AM
This is the other end of the bolt that I cut with my sawzoff.
  #70
Old 01-15-2018, 12:59 PM
These are some chips I made with my sawzoff.
