Old 01-11-2018, 10:26 PM
Default sealing holes in the reclaimed tin
I need some light bright pegs about 500 of them being when the lights are on at night and your outside of the building it looks like your at a planetarium watching the stars so i figure i can make the silicone go a bit further if i plug the holes with the light bright pegs
in short it sucked to be plugging all those holes took a few hours up and down the darn ladder... well mainly cause I was so smart each time I went up the ladder I only took one tube at a time instead of taking the lot of em... yep it's just been a blond moment all day...
..Randall.......Peace!
do nothing." -Edmund Burke-
Old 01-11-2018, 10:48 PM
Why not just put in a screw in each of the old holes?
Old 01-12-2018, 09:20 AM
Half the holes were oversized even for a lap screw some of the metal came off commercial building where they used a type of welded stud instead of screws sort of like the spot weld dent puller studs and cost per hole for lap screws silicon was a bit more cost effective.
where the light bright peg came from was just kidding around with a friend once we realized at night how many holes there were... look like a star constellation in a planetarium i got the big an small dipper in one wall and who knows what i could get out of the others maybe an open an closed sign that would flash when I'm welding
Old 01-13-2018, 08:31 AM
arcflash arcflash is offline
Would golf ball tees work?
Old 01-14-2018, 11:04 AM
The silicone worked just fine all that is left is to trim it out and door on front an maybe some of that spray on insulation later.
Old 01-14-2018, 04:26 PM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
Lexan caulk. Comes in solid colors as well as clear.
Klaatu barada nikto
