Old 01-11-2018, 04:20 PM
Default Bead Blaster
Been meaning to make a bead blaster since at least twice a year I have a tire that gives me trouble getting the bead to seat. Used a portable air tank and had all the fittings in the shop. Decided to braze the pipe since the wall thickness of a portable air tank is pretty thin.
Used 1" pipe and flattened the end to control the air stream. Added a rim stop to make it easier to hold the output end and keep it from going in too far and getting pinched by the tire. Leak tested the brazed pipe and all the fittings at 60#. No leaks.
I will get it painted when we get some warmer days. 40F and paint do not mix to well.
ID:	142964   Click image for larger version
ID:	142965   Click image for larger version
ID:	142966   Click image for larger version
ID:	142967   Click image for larger version
Old 01-11-2018, 11:06 PM
Gadgeteer's Avatar
But, this looks like way more fun.
Old 01-11-2018, 11:17 PM
I've probably done that a half dozen times in the past few years. Started using tire grease about 4 years ago. It works well, but damned messy. The blaster ought to make things a bit easier and a lot less messy. Always liked brazing. Slower than welding but much prettier.
Old 01-12-2018, 06:42 AM
That is much more fun. I have had good luck with that in the past. But I guess I was not using enough couple days ago on a skid loader tire. Tried it several times, but would not go blow up. I was using about same amount as the summer time and was thinking that the colder weather inhibited the flame up. I had to fight with a strap and finally got it.
I remember something about tire grease, and tried doing a search but did not find anything. What makes the tire grease different from regular grease?
Old 01-12-2018, 07:53 AM
Most people use Murphy's Tire Soap. It sort of looks like a big bucket of snot, but its just the right consistency to seal a bead and is pretty harmless to work with. I think normal grease like you would use to pack bearings would be bad for rubber, and it would be very expensive. A 25lb bucket of murphy's is maybe $40.
Old 01-12-2018, 09:50 AM
Nice build Chris....
The bead blaster makes quick work out of it over the tire soap I'm not fond of tire soap for a few reasons...but Chris is rite the bead blaster is less mess by far. It will also blow and help seat the bead on tires when the air injector on a tire machine will not on stubborn tire.
I use something similar but it's not portable its just a 25ft. one inch hose connected to my 60 gallon compressor with a valve on tank and bead gun on end.. works for the stuff around here mostly comes in handy for those stubborn ATV and garden tractor tires
..Randall.......Peace!
do nothing." -Edmund Burke-
Old 01-12-2018, 09:59 AM
We had a commercially made "Cheetah Tank" when I was mechanic at the sod farm, and a bunch of "drivers" that liked to run things over. I was changing semi tires or forklift tires 3 or 4 times a week (one guy came back with a forklift tire riding shotgun in the cab of the truck with the rim still in place,but the face of the wheel still bolted to the hub of the lift). The tank was great and most of the time it would work with no soap. I recommend eye and ear protection when you're messing with this stuff.
I do remember one time that a guy mangled a steer tire on his truck so it was vibrating a lot and I was told to put it on the trailer, and put a new tire on the truck. Between whatever he did to it, and then having to dismount and mount it on a different rim the bead just didn't want to seat. Finally broke down and used the murphy's soap AND the cheater tank. That was a fucking mess....
Old 01-12-2018, 10:03 AM
My son made a potato cannon from a 20 lb propane tank and a 10 foot steel pipe. He found a pneumatic dump valve cheap on ebay. The fast-acting one used for blowing out ducts and whatnot. Maybe 1 1/2" ID. Scary.
Old 01-12-2018, 10:12 AM
I see OTC makes a larger unit, with the tank on wheels.
Interesting, the valve is a common fuel dispenser valve, you can get the
1" npt non auto-shutoff one at TSC pretty cheaply.
https://www.tractorsupply.com/tsc/pr...n?cm_vc=-10005
Old 01-12-2018, 10:22 AM
Tire grease is not petroleum based so safe for rubber.
