JR Welding Tools
Old 08-10-2016, 10:45 AM
tackit's Avatar
tackit tackit is offline
Default need help reading mic
I just used my mic to find the shaft diameters of the extended reach tap holders. The larger shaft reads 4.0075 and the smaller one I read as 3.0076.
Can you guys check and or correct my readings out for me and tell me what drill size I should use to bore holes through the brass bushings?
I have "WHEELER ENGINEERING GUNSMITH LAPPING GRIT COMPOUND" I can put on the shafts to fit them if that is a good idea.
Thanks for your instructions and help.
ID:	134719   Click image for larger version
Old 08-10-2016, 11:14 AM
Unless I am out of sugar both are wrong, what pic is the large shaft and what one is the small?
Old 08-10-2016, 11:23 AM
tackit's Avatar
digr the first picture is the smaller shaft.
Old 08-10-2016, 11:27 AM
Isn't the first one 3.865?
Old 08-10-2016, 11:33 AM
I read them at .3711 and .4711 and I can't understand how a tap holder could be over 3"
Old 08-10-2016, 11:54 AM
noting the tenths reads up to 5 not 10 as other mic's.
.3706
.46605
Assuming you do not have a metric mic.
The smaller lines on the mic shaft are .025 each so you add them as you go past, 0-, .025, .050, .075-. .100
Both readings are past two lines so you add each line .025 + .025 = .050
Old 08-10-2016, 11:55 AM
I think they are .3706" and .466". Those are not nominal sizes, but I haven't checked metric cross reference yet. Sent from my iPhone using SFT
9.41mm and 11.8364 mm. I would not think they are metric.
The .3706 is close to .375 or 3/8", could your mic be off a little. Do you have a 1-2-3 block that you can check your mic against?
The .466 is just not what I would expect from a machining standpoint, unless it is custom made to certain holes.
Old 08-10-2016, 11:59 AM
.3706" and .466
First one we have .3, plus two graduations on the sleeve, .05
Barrel (thimble) shows .020, plus a .0005 graduation.
Vernier scale shows another .0001.
Add up
.3
.05
.020
.0005
.0001
For a total reading of .3706".
Two thumb typing on a phone, as I never have time to use a computer!
Old 08-10-2016, 12:04 PM
tackit's Avatar
I see your decimal point please allow me to blame it on my dirty glasses. Dollars, quarters and pennies got me again. I have to get a mic that reads in thousandth's, ten thousandths mics confuse the hell out of me.
Old 08-10-2016, 12:15 PM
tackit's Avatar
.3706" and .466
Add up
.3
.05
.020
.0005
.0001
Thanks greywynd.
I have to study your way of figuring out how to read a mic... I makes more sense to me, "I think", than the dollar quarters and cents method I'm not so good at.
