Old 03-13-2014, 08:47 AM
King of Obsolete's Avatar
Published Author
Default Will need lots of magic d5 blade
during the heat of the day yesterday i was able to dis-assemble the d5 blade. the blade is a little broken from hitting all the rocks on the winter road at least twice or maybe 3 times or more. first thing i need to find is the caterpillar measurements so i can measure up the blade to make it fit back on the cat. only problem is the cat is 400kms away and it will take 16hours to drive one way to take measurements.
thansk
KoO
Published Author
Name:	D5 blade km 20 lac brochet march 08 2014 035.jpg
ID:	113970   Click image for larger version
Name:	D5 blade km 20 lac brochet march 08 2014 038.jpg
ID:	113971   Click image for larger version
Name:	D5 blade km 20 lac brochet march 08 2014 040.jpg
ID:	113972   Click image for larger version
Name:	D5 broken blade disassemble march 12 2014 006.jpg
ID:	113973   Click image for larger version
Name:	D5 broken blade disassemble march 12 2014 010.jpg
King of Obsolete
Cat Train Tours
Old 03-13-2014, 09:00 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Default Very Cold Steel & Rocks
Joey. While getting Army Arctic Training at Camp Ripley in Minnesota, we as equipment operators had a class on what not to do with equipment in Subzero temperatures, one was not to ram rocks with a dozer blade as you could break parts a lot easier than you would think.
Repeat stress always finds the weak spot.
That does not look fun, but I am sure you can fix it.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 03-13-2014, 09:10 AM
Published Author
to build a winter road, all the rocks are hidden with about 2 feet of snow. all the snow has to be plowed off to get the frost to go down. that is when the rocks are found by the blade of the cat. some places the rocks are so bad it looks like god dropped his marble bag. this cat has been plowing for over 10 years and it finally broke big time.
thansk
KoO
Published Author
King of Obsolete
Cat Train Tours
Old 03-13-2014, 09:23 AM
This is a very interesting post, Thank you Joey for posting it,
and Dan for the helpfull info.
I hear people from "non cold areas" scoff at these accidents,
"It's mild steel, it'll just bend".
Or they'll even give some numbers:
"It's t-1, it has xx% elongation"
They don't understand charpy impact values at reduced temps.
For example, the neighbor bought a very similar dozer last summer
from salvage, it had rolled....down a cliff, and smashed the ROPS,
dashboard, hood tin, etc.
The local fab shop pulled the whole blade assembly off (pretty
much like what you showed here) and it was bent big time.
Pretzelled up fierce.
They had to cut it all apart and weld in new.
But no cracking at all.
Old 03-14-2014, 07:57 AM
Scrapper Greg's Avatar
Yes steel does funny things when it gets cold. It changes big time at about -40 or so. Where we bend they break. Kinda glad I'm down here.
MAGA
Old 03-14-2014, 09:36 AM
One thing to note, when steel crystallizes and breaks from the cold it becomes magnetic around the break. I bought a Case 24B that had been used at Fairbanks military base. After a week of use, one if the loader boom arms broke. It had been welded by someone who imagined they could do it on 2" steel.
I took a compass and went over the other arm and lo and behold, it was cracked in the same area, according to the compass.
So I Vee cut the break on the busted side and left 1/4" in the middle to index to, and when that was done, I cut out the mag metal in the break area on the other arm and did that one....no more trouble.
Joey, is that C frame busted?
Old 03-14-2014, 07:54 PM
akabull's Avatar
akabull akabull is offline
Maine-iac
I don't know a damn thing about Dozer nor the great white north.....but I do know that I am glad Joey is doing this job and not me! Based on what I've seen of Joey's skill, I'm sure he will be backup a running in no time.
Chris in Maine
Old 03-14-2014, 08:15 PM
Let me see if I have this correct you checked for cracks using a compass
Old 03-14-2014, 10:52 PM
...Joey, is that C frame busted?
Yeah, I was wondering the same--looks like it's the C-frame that's broken. Is the blade itself OK?
Magnetic particle testing--only works as you get close to the North Pole...
Old 03-16-2014, 01:36 AM
Never heard of broken metal being magnetic, that's a cool trick to remember.
When I was working in the oil patch at Prudhoe Bay (top of Alaska) in the early 80's the outfit I was with was drilling a lot of 18" holes in frozen ground for pipeline VSM's (Vertical Support Members). They had several Watson Drills using Pengo augers and in the frozen ground there was a lot of bouncing, chattering and jerking. At -35F they would shut down the drills and everyone but the mechanics would stay in camp until the temperature came back up. The company figured if they ran the machines in colder weather than that, the parts they were breaking were costing considerably more than they were making. Same with the ripper cats, even in shot and fractured (frozen) sand.... shut 'em down.
