Don't try this at home - UNLESS you live in a HOSPITAL! |
Well, anything is possible, the question probably is whether or not it's practical. The waste oil heater in our truck shop (350,000Btu Reznor) does not share that much in common with a regular oil burner. It takes compressed air to make the thicker oil atomize properly, and it has several more safety and limit switches than a fuel oil unit. My main concern would be if the heat exchanger in the regular unit would stand up to the higher Btu/gallon of the waste oil. That being said, if all of the waste oil heaters give as much trouble as the one we bought, I'd probably just as soon wear a coat.
sbi1 Good judgement comes from experience. Experience comes from bad judgement. |
Maybe the newer units are better; but I had one about 10 years back that was a huge PITA. It required constant attention and my big problem was getting GOOD waste oil. Lots of people will be your pal because you are getting rid of their oil; but they try to sneak in all kinds of crap. It's not as easy or economical as it appears unless YOU generate a huge volume of oil for yourself.
I agree with the negatives you can come up against, but it can be done at a huge cost savings if you can get the cleaner less contaminated waste oils. Just make a point to stay away from those that add their waste coolants and floor sweepings. lol
Do some searches on the web and you'll find more information on the home brew and home do-it-your-selfer retro's than you'll have time to read. It will work, but as said, it may take a little piddling to get something that is safe and cost effective. LW
Can we talk of integration until there is integration of hearts and minds? Unless you have this, you only have a physical presence, and the walls between us are as high as the mountain range. Chief Dan George Peace is that brief glorious moment in history when everybody stands around reloading T.J. Last edited by LW Hiway; 10-19-2006 at 04:00 PM. |
made one out of an old gas can and a 12" piece of pipe. need to add forced air, but i originally built it for disposal. smokes a bit without the air. if i'm doing it indoors i add a small air stream from compressor. burns clean. large airstream get very hot 1000* or more and 15 foot flame. :evil:
thats a pretty cool idea. i never herd of using old oil for heat, shore wish i could convert my house. paid over $3,000. last winter
and not shore if i can even aford to heat this winter, might just light the couch on fire for heat.
James i like the new :evil: MM135 spec125 TA-185 Victor O/A setup Miller BWE hood saving for MM210, Spectrum 375, ............. ![]() feel free to PM or e-mail me directly metalart@peoplepc.com , i have lots of time to chat. |
Fun for now I do heating and air for a living and I am about to give you my secret for heating my house in the winter
. I use the oil filled radiant heaters that look like the old steam radiators that most peaple had in their homes before forced air became popular . You can get them at Wally world for around $35.00 bucks and Lowes has em on sale for about $26.00 right now . There now I will tell you the secret I set the blower switch on my thermostat to on durring the winter and it circulates the heat from the radiant heaters through the house . They cost about $10.00 bucks a month to run here each which beats the Heck out of a $250.00 gas bill or worse each month .Rick
if it aint broke fix it till it is Proud member of the garbage gang and sub chapter Mole Hill gang ![]() Politically Correct : A term used for whiny pu**ies that need sh*t sugar coated . |
i
ll have to give that a try, we have cieling fans in all the rooms so i dont think i would need the heater to circulate the air. thanks for the tip, i'll give them a try. are tey hot enough i have to worry about the babby getting burned ???
You have to make sure you filter the used oil well before sending to the burner. Water and anything chlorinated will kill you on BTU value. If you can preheat the oil prior to sending to the burner the better atomization you will get. Boilerman can fill you on the details of that.
BT's are useful at times...
Shade, Keeper of the Insane Asylum. "Live Free or Die" -- the official motto of New Hampshire A Liberal lives life fearing the evil a man might do. A Conservative lives life celebrating the good a man does. -- JonM@FTF Patriots are not revolutionaries trying to overthrow the government of the United States. Patriots are Counter-Revolutionaries trying to prevent the government from overthrowing the Constitution. -- Unknown When The People fear their government, there is Tyranny. When The Government fears The People, there is Liberty. -- Thomas Jefferson An Armed man is a Citizen, An Unarmed man is a Subject. -- Unknown To those who have fought for it, freedom has a flavor the protected will never know. -- Scrawled on a bunker outside Khe Sahn, RVN |
| Thread Tools | |
| Display Modes | |
